mtuhoop24
Oct 29, 2016Guide
Orbi loosing Internet Connection
Hello - I have had my Orbi installed for less than a week. 3 time now it has lost all connection to the internet. I have to reboot, unplug, both the Orbi and my modem multiple time before I can get...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
kennedyd013
Nov 26, 2016Guide
Just upgraded to the latest firmware on everything. Still way too soon to tell - the addition of guest wireless is super nice. That was a big missing feature. Will check it out for a couple days and report back.
mtuhoop24
Nov 27, 2016Guide
How is the new firmware? It isn't listed on NetGear website.
- Hydro130Nov 28, 2016Luminary
mtuhoop24 wrote:How is the new firmware? It isn't listed on NetGear website.
I updated the FW on Friday night, and so far so good - everything has been working tip-top, but I wasn't having any issues at all with previous FW versions either.
To do the update, I just kept refreshing my Firmware page within my Orbi's Admin page throughout the evening... The first several times I tried, it would load an update link for the router or the sat, but not both (one or the other would hang or just not load).
Finally, later that evening, I got both update links (router and sat) on that that page to load up, and so I did the update from there. It went fine.
Cheers, Chris
