mtuhoop24
Oct 29, 2016Guide
Orbi loosing Internet Connection
Hello - I have had my Orbi installed for less than a week. 3 time now it has lost all connection to the internet. I have to reboot, unplug, both the Orbi and my modem multiple time before I can get...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
mikelagase
Dec 05, 2016Guide
I still have to reset the router every morning after applying latest updates. Will try factory resetting the router/satellite to see if that helps.
DarrenM
Dec 07, 2016Sr. NETGEAR Moderator
Hello mikelagase
Yes try a factory reset sometimes strange issues happen after doing FW updates and factory reset typically fixes it.
DarrenM
- Retired_MemberDec 16, 2016
Since this update, my issue with my internet not working seems to have gone away. Will keep an eye on it longer.
