mtuhoop24
Oct 29, 2016Guide
Orbi loosing Internet Connection
Hello - I have had my Orbi installed for less than a week. 3 time now it has lost all connection to the internet. I have to reboot, unplug, both the Orbi and my modem multiple time before I can get...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
fstockel
Jan 05, 2017Star
As I wrote in another thread. This might be worth trying:
I tried to change to the TP-cable that came with the box and this might have solved it for me (well no connection drop in approx 3hrs so far). Funny thing is that my previous cable was a hq/expensive cable (had zero issues using it with my previous Asus router). Fingers crossed.
Yld2rob
Jan 06, 2017Luminary
ON .34 Firmware. Devices starting dropping an hour ago :( Rebooted. It is back up. Let's see for how long!
