mtuhoop24
Oct 29, 2016Guide
Orbi loosing Internet Connection
Hello - I have had my Orbi installed for less than a week. 3 time now it has lost all connection to the internet. I have to reboot, unplug, both the Orbi and my modem multiple time before I can get...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
fstockel
Jan 05, 2017Star
Sorry to say but I'm facing the same issue with 1.4.0.34. My internet connection still keeps dropping (several times a day). Same as with previous firmware version 😫😢
This is *really* frustrating. Any ideas? Any news from Netgear?
JMU1998
Jan 08, 2017Luminary
.16 I have found to be the most stable at the moment you can roll back to it then do factory reset until Netgear release a stable Firmware.
- Yld2robJan 09, 2017Luminary
I rolled back to .16 today. Hopefully that will keep it up. I don't remember any disconnects with that version of firmware. Let's hope the Orbi doesn't do an auto firmware update!
- GuyMontagJan 10, 2017Initiate
I've been having the same dropped connection issues while using the 1.4.0.34 firmware.
Symptoms:
- Internet drops on wireless only for a few minutes at a time (2-3 times a day).
- Wired connections continue to work just fine indicating the issue is only with Orbi.
I just rolled back to the 1.4.0.16 firmware. Will report back in a few days with results.
Thanks for posting about this, it really helped me track the issue down.
Is the factory reset necessary after installing new firmware?
- Yld2robJan 10, 2017Luminary
Bad new. I rolled back to .16 yesterday and this morning, the router lost connectivity. Had to power cycle. If this continues another couple days this is getting returned!
