mtuhoop24
Oct 29, 2016Guide
Orbi loosing Internet Connection
Hello - I have had my Orbi installed for less than a week. 3 time now it has lost all connection to the internet. I have to reboot, unplug, both the Orbi and my modem multiple time before I can get...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
DarrenM
Feb 14, 2017Sr. NETGEAR Moderator
NETGEAR is aware of an issue affecting some users where wireless client devices frequently disconnect/reconnect from the Orbi WiFi network. We’re actively working on the issue and hope to have a solution soon.
Thank You
DarrenM
mikelagase
Feb 14, 2017Guide
It would be great if we can get this fixed soon as I have my Orbi in the box ready to return or sell the darn thing. The entire family was so tired of disconnects and lack of internet connectivity that I had to switch back to my old router.
I may just keep the Orbi for now and try with the next update to see if that makes any difference otherwise this thing is going back which is unfortunate. It works great when it works but horrible that I had to reset the router so many times a day.
