mtuhoop24
Oct 29, 2016Guide
Orbi loosing Internet Connection
Hello - I have had my Orbi installed for less than a week. 3 time now it has lost all connection to the internet. I have to reboot, unplug, both the Orbi and my modem multiple time before I can get...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
millerre1959
Mar 03, 2017Star
If I may ask, what made you decide to go with 2 satellites? I ask because we may be moving to a larger home in the near future, and I wondered if that was your rationale for having a 2nd satellite.
Retired_Member
Mar 03, 2017It was part of the package and we have a large one story on one acre with 3 car garage. So normal routers couldn't cover the whole house. The Orbi did, with the one in the far corner, and the satelite in the middle of the house which reached the garage, kitchen, master on the other side of the house fine even into the back/front yards of our 1 acre.
