mtuhoop24
Oct 29, 2016Guide
Orbi loosing Internet Connection
Hello - I have had my Orbi installed for less than a week. 3 time now it has lost all connection to the internet. I have to reboot, unplug, both the Orbi and my modem multiple time before I can get...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
RickDangerous
Mar 23, 2017Star
peteytesting wrote:seeing as no one not even netgear has ventured into this distributed wireless world before its a steep learning curve for all manufactures and no one has background knowledge to look back on for this technology , so its baby steps and yes bugs along the way
I hear you, but its simply not acceptable for Netgear to sell a £360 product (in the UK at least) that does not function as advertised.
For what it's worth I think folks who've had a bad experience (like me) should start posting negative Amazon reviews, as I think that'll get them moving a little bit quicker on finding a solution.
Retired_Member
Mar 23, 2017Yep, negative Amazon review already done. :)
