mtuhoop24
Oct 29, 2016Guide
Orbi loosing Internet Connection
Hello - I have had my Orbi installed for less than a week. 3 time now it has lost all connection to the internet. I have to reboot, unplug, both the Orbi and my modem multiple time before I can get...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Retired_Member
Mar 25, 2017Eero. No issues. :)
whsbuss-1
Mar 25, 2017Apprentice
@killabandit wrote:
Eero. No issues. :)
Well maybe for you, but if you check their fourms others have issues.
- st_shawMar 25, 2017Master
whsbuss-1 wrote:
@killabandit wrote:
Eero. No issues. :)Well maybe for you, but if you check their fourms others have issues.
Plenty of verfied purchasers on Amazon claiming disconnects, slow speed, other issues with Eero. See below link. Eero has 7% 1-star reviews. Orbi has 4% 1-star reviews.
Both products have users with issues. This is not unusual and doesn't mean either product is bad. It just sucks if you're one of the few with issues.
