mtuhoop24
Oct 29, 2016Guide
Orbi loosing Internet Connection
Hello - I have had my Orbi installed for less than a week. 3 time now it has lost all connection to the internet. I have to reboot, unplug, both the Orbi and my modem multiple time before I can get...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Retired_Member
Mar 25, 2017Eero. No issues. :)
B747driver
Mar 25, 2017Star
@killabandit wrote:
Eero. No issues. :)
Same here. I haven't had to do a single reboot or reset since initial setup nearly a month ago. No iOS or Nest Cam drops. Everything has maintained a rock solid connection. I don't run around the house doing speeds tests all day, nor do I feel the need to do so. I have better things to do. All I know is that all of my devices perform just fine everywhere in my home, which is all I really care about.
Eero may not have some of the tech specs or features that some of the newer systems like Orbi and Velop have, but none of that matters if you're constantly aggravated by connection issues. Further, and JMHO here, but disabling any feature or function (i.e. beamforming) to get "normal" performance is a symptom that something is inherently wrong with the system. No such problems with Eero - it just works. As always, YMMV.
- Retired_MemberMar 25, 2017
Exactly my point. Eero just works. Orbi doesn't. I gave them 6 months trying to resolve it, and I still see they haven't. I don't see a benefit using them if you can't have a stable wifi system in the first place.
