mtuhoop24's avatar
Oct 29, 2016
Orbi loosing Internet Connection
Hello - I have had my Orbi installed for less than a week.  3 time now it has lost all connection to the internet.  I have to reboot, unplug, both the Orbi and my modem multiple time before I can get...
  • DarrenM's avatar
    DarrenM
    Jul 11, 2017
    Hello Everyone
    We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
    https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
    If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
    http://www.netgear.com/support/contact.aspx
    Thanks
    DarrenM
