mtuhoop24
Oct 29, 2016Guide
Orbi loosing Internet Connection
Hello - I have had my Orbi installed for less than a week. 3 time now it has lost all connection to the internet. I have to reboot, unplug, both the Orbi and my modem multiple time before I can get...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Retired_Member
Mar 25, 2017Like I said kid. You are the ones that started this. I said to stop it many pages ago and you continue. Again. No one cares about your orbi that does work. Help the ones that don't and stop bad mouthing those that have had them in the past trying to help those people. Again, go back and look and you will see you guys started this crap. Get a life.
peteytesting
Mar 25, 2017Hero
lol all i can see you doing is trolling and complaining and not really helping anyone , its obvious some are having issues , its obvious netgear are trying to solve them , its obvious that continually trolling and complaining just annoys ppl , so how about do something else apart from abusing those that dont see your point of view
- Retired_MemberMar 25, 2017
Funny thing is, you annoy people here. I have actually helped many since I have been here. Like I said, NO ONE CARES IF YOURS WORKS FINE. Help those that don't.
Where is your logs? We asked you to post them to prove you don't have issues, but you still won't do it.
- peteytestingMar 25, 2017Hero
where is the mute button lol
ah found it
for others click on the users name and when the next page opens go over to the right and click on ignore user , problem solved
So why don't you want to post your logs? You lying then?
