mtuhoop24
Oct 29, 2016Guide
Orbi loosing Internet Connection
Hello - I have had my Orbi installed for less than a week. 3 time now it has lost all connection to the internet. I have to reboot, unplug, both the Orbi and my modem multiple time before I can get...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
abouthere
Apr 29, 2017Tutor
I tried replacing my VDSL modem with a Netgear DM200. What a farce and waste of time that was. Three hours effort and it didn't work. Gone back to the Openreach provided modem (in bridge mode) and turned off some of the Orbi settings folks have mentioned here.
New firmware came out in the last few days too so let's see if that makes any difference too. Can't see any setup changes so must be under the hood fixes.
