mtuhoop24
Oct 29, 2016Guide
Orbi loosing Internet Connection
Hello - I have had my Orbi installed for less than a week. 3 time now it has lost all connection to the internet. I have to reboot, unplug, both the Orbi and my modem multiple time before I can get...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Malik2k1
May 11, 2017Star
I honestly don't understand how the Orbi can cause so much havoc on a network while running in AP mode. I have a nighthawk r7000 doing all the backbone work in router mode and my wired connections are affected even though they're not running through the Orbi...
So frustrating. i understand fixes take time but rolling back could at least help keep us running properly until a better firmware is available. I honestly don't know why it's not an option for us. :(
jleecloak1
May 11, 2017Apprentice
I agree, even in AP mode it disconnects on wired connections. The Orbi has to be shut off from your network period. This product wasn't ready and we should demand it be fixed or be refunded for a faulty product.
- JMU1998May 12, 2017Luminary
I have it in AP mode and wired connection drops for a second about 2 to 3 times a day but only for a second very annoying.
- ReturningmyorbiMay 13, 2017Tutor
For those who stil believe they give a 💩:
Re: Betreff: Connection issues to satellite and with iOS devices
Options
2017-02-02 06:04 PMOur engineers are aware of the issues with IOS devices and are working to correct the Issue. I do not have a ETA on the fix or the firmware but will post once I know something.
This is more then three Months back.... 😢
- peteytestingMay 13, 2017Hero
