mtuhoop24
Oct 29, 2016Guide
Orbi loosing Internet Connection
Hello - I have had my Orbi installed for less than a week. 3 time now it has lost all connection to the internet. I have to reboot, unplug, both the Orbi and my modem multiple time before I can get...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
AMarket42
Apr 29, 2017Star
mixolyd
May 15, 2017Star
Is WMM option somewhere else now? I do not see it in QoS settings in Advanced. I would like to try to disable it and see if that fixes my internet drops.
I am losing internet connection intermittently. I started running Pingplotter on my windows machine and set it to ping google.com and the local router IP every 5 seconds. Every few hours google.com becomes unpingable for 1-5 minutes, but the router stays pingable, so it's clearly a WAN issue. When I am home and notice this, then rebooting the router fixes it.
I bought the Orbi from Costco which has a 90 day return policy. I think I'm getting close to 90 days, so I'm debating on returning it. This is really unacceptable for a $400 device. I really like Orbi otherwise, but I cannot deal with the internet disconnects. I am on latest firmware and have tried factory reset.
- jw127May 15, 2017Aspirant
Log in to router. Go to Advanced>advanced>wireless settings>uncheck the boxes for WMM for both frequencies and Apply. You're done!
- mixolydMay 15, 2017Star
Thanks! I'll give it a try, although I just realized something. I had the router in Pingplotter along with google.com, and yesterday I noticed that when pings were red to google, the router was Ok. But I just checked readings from last night and today, and the router was unpingable for about 3 minutes a few times along with google.com... so this seems like more of an issue than just losing WAN connection... This is with a computer hire wired to a Satellite btw. Not sure what's going on here. Is contacting Netgear support worth it? Seems like a bunch of you guys tried which didn't amount to much
I just saw in another thread mention of a beta firmware. Have any of you guys tried that?
- FouduRoiMay 24, 2017Tutor
Indeed, apparently there is a beta version that fixes the issue which is a good news. Now the question is when it will be released????
