mtuhoop24
Oct 29, 2016Guide
Orbi loosing Internet Connection
Hello - I have had my Orbi installed for less than a week. 3 time now it has lost all connection to the internet. I have to reboot, unplug, both the Orbi and my modem multiple time before I can get...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
jleecloak1
Jun 16, 2017Apprentice
If this is the reason I am getting disconnected then Netgear has to fix this none of my other routers I have owned has had this problem. I'm not going to spend hours on the phone talking to Comcast because my Orbi can't stop disconnecting that's a no from me.
DarrenM
Jul 11, 2017Sr. NETGEAR Moderator
Hello Everyone
Thanks
DarrenM
