Mike34848
Jul 22, 2017Aspirant
Orbi loosing internet connection
Hi all, problems with my orbi loosing internet connection. I have had this orbi for several months and it had been working super. Now it is connected to my modem for max 30 seconds and then it lose...
DarrenM
Jul 24, 2017Sr. NETGEAR Moderator
Hello Mike34848
Have you tried to enable beamforming and mumimo some people have said since the update when they enable it again seems to fix the issue.
DarrenM
Mike34848
Jul 27, 2017Aspirant
Hi DarrenM,
thanks for your ideas. I have been away a few days, but I will try enabling beamforming and mumimo. I first have to find out how to do that...
And I will try the factory default reset first, have not done that after the firmware update.
mike
