Mike34848
Jul 22, 2017Aspirant
Orbi loosing internet connection
Hi all, problems with my orbi loosing internet connection. I have had this orbi for several months and it had been working super. Now it is connected to my modem for max 30 seconds and then it lose...
DarrenM
Jul 27, 2017Sr. NETGEAR Moderator
Hello thedigitaltuner
Have you done a factory reset since being on the latest firmware?
DarrenM
thedigitaltuner
Jul 30, 2017Aspirant
I have not done a factory reset, that sounds painful as assume i would lose all settings. Why would that be required? Is this not your top of the line equipment?
- DarrenMAug 01, 2017Sr. NETGEAR Moderator
Hello thedgitaltuner
You can backup your settings before the factory reset. All you need to do to factory reset the unit is hold the reset button for 10 seconds. I linked how to back up your config.
DarrenM
