Jason2112
Jan 05, 2019Aspirant
Orbi loosing Internet Connection
I know this topic has been drug through the mudd! I’m thinking the system is overkill because it’s in my 5th wheel. Which is 40ft total. And the satellite is about 20ft from the base. It’s hard to say...
Blanca_O
Jan 08, 2019NETGEAR Employee Retired
Hi Jason2112
We’d greatly appreciate hearing your feedback letting us know if the information FURRYe38 provided has helped resolve your issue or if you need further assistance.
Blanca
Community Team
Jason2112
Jan 10, 2019Aspirant
Not 100% sure it’s fixed. I’ve not seen many drops. But have some real slow speeds in the morning. Not sure why.
- FURRYe38Jan 10, 2019Guru - Experienced User
Slow speeds wired or wireless?
What WPA security modes are you using?
