Retired_Member
Dec 25, 2016Orbi loosing port forwarding or something else happening
Mine hasn't had the internet loose connection any more, but I have an issue that is irritating. You know in some games when you join up on each other, like Call of Duty Infinite Warfare or Black Ops...
RonV42
Dec 26, 2016Luminary
Strange I have had the Orbi for about 3 weeks now and both my Xbox One's have open nat. I don't manually configure any port opens in the router since the Xbox will open ports as needed.
If you have configured open ports make sure you are using a manually assined IP for your xbox in the configuration of your Orbi. Advanced Tab / Setup /LAN setup and then you can reserve the address for your Xbox there.
Now verify your Xbox has that address by gonig into settings, network and dispaly the network address and make sure if matches the reservation. If it doesn't then reboot the xbox and check again.
The last step is to verify your port opens. There are many ports you need to open for Xbox:
TCP: 53, 80, 3074
UDP: 53, 88, 500, 3074, 3544, 4500
Go into your Orbi to the Advanced Tab / Advanced Setup / Port Forwarding and adjust the ports there.
After that re-run the network test on the XBox one to validate connectivity and Open NAT. If it does go away after a period of time there is deeper diggings into the logs or you may have to open a service request with Netgear.
