Retired_Member
Dec 25, 2016Orbi loosing port forwarding or something else happening
Mine hasn't had the internet loose connection any more, but I have an issue that is irritating. You know in some games when you join up on each other, like Call of Duty Infinite Warfare or Black Ops...
Retired_Member
Dec 26, 2016It's actually for the PC version of the games. All ports are setup correctly for it as it shows open when it works right then after a week it goes to strict till I reboot the router. Very frustrating.
RonV42
Dec 26, 2016Luminary
Ok thanks for the info. I assume you are using manually assigned IP address for the PC then. Strange becuase I do have port forward to support my Media Server from outside the home and never seen it get blocked or disabled by the Orbi. You may want to open a support ticket with Netgear on this one.
- Retired_MemberDec 26, 2016
Yes, sorry I should have answered that on the first post. I have a static IP set on the PC, so the router sends the port fwd to that IP. I may have to do it. Thanks.
- Retired_MemberDec 28, 2016
It just happened again. I am about fed up with this crap. I can't keep having to reboot this router this often because of this. Even after locking in all the IPs as reservations the issue is still happening. :/- JMU1998Dec 28, 2016Luminary
This was not happening on 16 Firmware but have noticed it on 18 on a few games hopefully Netgear is aware and will address in next Firmware.
