Retired_Member
Dec 25, 2016Orbi loosing port forwarding or something else happening
Mine hasn't had the internet loose connection any more, but I have an issue that is irritating. You know in some games when you join up on each other, like Call of Duty Infinite Warfare or Black Ops...
RonV42
Dec 26, 2016Luminary
Ok thanks for the info. I assume you are using manually assigned IP address for the PC then. Strange becuase I do have port forward to support my Media Server from outside the home and never seen it get blocked or disabled by the Orbi. You may want to open a support ticket with Netgear on this one.
Retired_Member
Dec 26, 2016Yes, sorry I should have answered that on the first post. I have a static IP set on the PC, so the router sends the port fwd to that IP. I may have to do it. Thanks.
- Retired_MemberDec 28, 2016
It just happened again. I am about fed up with this crap. I can't keep having to reboot this router this often because of this. Even after locking in all the IPs as reservations the issue is still happening. :/- JMU1998Dec 28, 2016Luminary
This was not happening on 16 Firmware but have noticed it on 18 on a few games hopefully Netgear is aware and will address in next Firmware.
