rodneymiller12
Mar 02, 2018Follower
Orbi loses internet connection with Comcast
Having issues with My Netgear Orbi and connectivity to my Comcast modem At least once a day my orbi loses its internet connection with the modem. I have the modem setup in bridge mode, my router and...
naerok
Mar 02, 2018Apprentice
this is a known issue documented in this post: https://community.netgear.com/t5/Orbi/What-you-can-expect-with-your-Orbi-system/m-p/1503034#M23257
good luck - so far the only solution seems to be putting a smart outlet / timer on your satellite(s) to reboot them once every 24 hours (I'm not joking) or rolling back the firmware (but I still see people saying they experience the same issues on the older firmware)
see this guy: https://community.netgear.com/t5/Orbi/Orbi-satellite-dropping-connection/m-p/1512445#M24230
Don't listen to the netgear shills on these forums that blame the user and give you the same bs about trying to disable beamforming/mimo or moving the satellites closer to the router. Waste of time until netgear releases a fix.
