tonypap
Apr 09, 2018Tutor
ORBI LOSES/DROPS INTERNET CONNECTION
RBR50 keeps losing internet connection. All devices are conntected to the orbi WiFi but there is no internet connection. The internet connection is dropped mulitple times per day. I currently have...
Aug 04, 2018Guru - Experienced User
What happens if you turn of the all of the following?
5 Google home, two echo, Chromecast ultra, and Phillips hue with 17 lights
Npran wrote:
What is the Mfr and model# of the IP modem the Orbi is connected too?
Actiontec T3200M
2000
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
40ft
Channel 6
Yes, about 11 other broadcasted ssid
Try disabling the following:
MIMO, Daisy Chain, Fast Roaming, IPv6. Save settings and reboot the router and satellite(s)
All disabled currently. Also, I reduced the broadcast strength of 2.4 GHz to 50% and 5 GHz to 75%.
I have 5 Google home, two echo, Chromecast ultra, apple TV, Phillips hue with 17 lights, TV, ps3, ps4, Nintendo switch, Asus rp-a68u (bridge mode), two phones (iPhone and note) a tablet, two laptops (MacBook pro and windows 10) and wireless printer connected wirelessly.
Seems stable today, was up until 4 am configuring and signing reserved addresses to everything. Been using the smartphones intermittently, MacBook frequently and ps4 most part of the afternoon without a hitch.
Npran
Aug 05, 2018Guide
I'll try it out, but that's not really a fix. If a router can't handle a smart home, it has no business being on the market in this day and age.
Yesterday, the satellite crashed twice, and it seems like when the 2.4 GHz is utilized its when hell breaks loose. I think I'm going to try with no 2.4 GHz as I do have a bridge for the items that still utilize the older standard.
Thank you
Thank you
