tonypap
Apr 09, 2018Tutor
ORBI LOSES/DROPS INTERNET CONNECTION
RBR50 keeps losing internet connection. All devices are conntected to the orbi WiFi but there is no internet connection. The internet connection is dropped mulitple times per day. I currently have...
Aug 05, 2018Guru - Experienced User
Good Luck.
Npran
Aug 08, 2018Guide
Just an update, but after trying some setting changes; no improvements were made. The stability would only get worse to the point of resets every couple of minutes. The most stable setting would disconnect every 45 minutes to an hour.
Unit is returned to the retailer as the stability was too much of an issue.
Thank you for the help though.
