tonypap
Apr 09, 2018Tutor
ORBI LOSES/DROPS INTERNET CONNECTION
RBR50 keeps losing internet connection. All devices are conntected to the orbi WiFi but there is no internet connection. The internet connection is dropped mulitple times per day. I currently have...
revangel
Aug 14, 2018Star
Latest firmware 2.1.4.16, 1 RBR50+2 RBS50 satellites: one satellite wired connected (backhaul) and another less than 30 feet from router. The connection drops 5-7 times a day. Can Netgear send me a debug firmaware package so they can better analyze the issue? I tried the suggested setup (fixed a channel, disabled some options, etc) but I got the same results. 2 months ago I had no issues and now Orbi is consistently dropping connection to internet.
Aug 14, 2018Guru - Experienced User
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Any network switches in the mix? Mfr and model# of the switch being used.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
NG doesn't send out debug FW. Can join up for this:
If you having continued issues, you can phone contact NG support and ask for additional help and information. Ask for an RMA if you feel the system is faulty.
- revangelAug 16, 2018Star
My modem: ARRIS BGW210-700 (ATT Fiber 1000 MBPS)
