tonypap
Apr 09, 2018Tutor
ORBI LOSES/DROPS INTERNET CONNECTION
RBR50 keeps losing internet connection. All devices are conntected to the orbi WiFi but there is no internet connection. The internet connection is dropped mulitple times per day. I currently have...
Aug 17, 2018Guru - Experienced User
Your modem is a gateway router...
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
