Escondido
Nov 28, 2017Tutor
Orbi losing packets
Hello, I'm seeing packet losses with my Orbi. I have the RBK53 (RBK50, boxed with two remote Orbi devices). The Orbi is hardwired to my firewall. Also hardwired to my firewall is a Linux...
Escondido
Jan 02, 2018Tutor
A little bit more information on my post - I am running my tests while connected via WiFi to the router, not a satellite.
At Webminster's suggestion, I am going to ping test different devices connected to router/satellites to see what happens.
Escondido
Jan 06, 2018Tutor
So far I'm not losing packets. I'm not sure if it was due to the firmware update or the rebooting of the devices.
I ran a ping test to 8.8.8.8 for 1.5 days. On average, I am losing about 8 ms in latency using WiFi vs. hardwired, but I can live with that.
I'll continue to monitor to see if I get any packet losses, but so far things are looking good.
- webminsterJan 06, 2018Luminary
Just installed the 2.1.2.10 beta this morning, been running a couple of casual tests. Hasn't helped my latency variations though the satellite to some hardwired addresses on my local network. Variations on a local Linux box from 2ms to 300ms, sometimes no packet loss, sometimes between 1% and 20+%. The loss and variances are cyclic. Tried looking at Wifi Analyzer for any obvious conflicts on the 5G band, don't see any.
- jmschnur923Jan 06, 2018Luminary
Using ping to my fios gateway I am getting no packet loss with about 5ms latency.
thr route is far sat to sat one to Orbi router to fios gateway.
daisy chain. 2.1.2
I did get losses and much more latency in precious firmware version.
I tried several devices. About 1000 pings. One was lost. Late Cy varied from 2-11 ms.
