Walkmic3
Oct 17, 2017Guide
Orbi Losing wifi connection
I have had the Orbi AC 2200 for a month now. 2 to 3 times a week we completely lose our wifi.
DarrenM
Oct 19, 2017Sr. NETGEAR Moderator
Hello Walkmic3
Do you check your modem when you lose connection to see if that goes out as well?
DarrenM
Walkmic3
Oct 19, 2017Guide
Yes the modem is staying connected and if I am headlined into to orbi’s router I still have internet. The WiFi single from Orbi just cuts out.
- DarrenMOct 20, 2017Sr. NETGEAR Moderator
Have you tried to enable beamforming and mumimo in the Advanced wireless settings?
DarrenM
- Walkmic3Oct 20, 2017GuideNo I have not. I have no clue how to do that either.
- Walkmic3Oct 21, 2017GuideHey Darren thanks I figured out to turn that. I’ll give it a try. I have the 3 pack 43. So I hope those aren’t the ones with the WiFi problem
- DarrenMOct 23, 2017Sr. NETGEAR Moderator
If you are experiencing disconnects after the latest firmware update send me a PM with your name email and phone number and I will get you in contact with our support team to troubleshoot the issue.
DarrenM
- snajmusOct 21, 2017Aspirant
