Walkmic3
Oct 17, 2017Guide
Orbi Losing wifi connection
I have had the Orbi AC 2200 for a month now. 2 to 3 times a week we completely lose our wifi.
Walkmic3
Oct 19, 2017Guide
Yes the modem is staying connected and if I am headlined into to orbi’s router I still have internet. The WiFi single from Orbi just cuts out.
DarrenM
Oct 20, 2017Sr. NETGEAR Moderator
Have you tried to enable beamforming and mumimo in the Advanced wireless settings?
DarrenM
- Walkmic3Oct 20, 2017GuideNo I have not. I have no clue how to do that either.
- Walkmic3Oct 21, 2017GuideHey Darren thanks I figured out to turn that. I’ll give it a try. I have the 3 pack 43. So I hope those aren’t the ones with the WiFi problem
- DarrenMOct 23, 2017Sr. NETGEAR Moderator
If you are experiencing disconnects after the latest firmware update send me a PM with your name email and phone number and I will get you in contact with our support team to troubleshoot the issue.
DarrenM
- snajmusOct 21, 2017Aspirant
I appreciate the response. However, it is incomplete. May I have a STRAIGHT AND CLEAR ANSWER as to whether the internet connection problem is solved COMPLETELY and what are the steps. OR is it still a trial and error - try this, try that, AND PRAY.
Where can I find the solution and status to this internet connection drop and IOS connection drop problem reported by many many customers.
Please be straightforward - is it truly SOLVED or is it NOT.
- shanwaOct 21, 2017Tutor
The only way I've been able to keep a stable wireless network is to turn my RBR50 into an Access Point. Having it set to Router mode meant that my wifi would drop multiple times a day. I've spent an hour with support on the phone with a guy that had difficulty with english, to advise that I had a hardware problem and to return it to the place of purchase. I received a replacement immediately from Bestbuy and it did the exact same thing. I've updated my ticket on Netgears support site to receive zero response. This is a second class product we pay a premium for with **bleep**house support.
Hello
Thanks for your response. I hope NetGear is paying attention to these comments. On the AP matter, can you explain a little bit more. So, do you get high speed connection at every corner of your house; in essence your Satellite connections are to the Cable Modem router, not the Orbi router, right?
I don't understand all of it - needs little more advice from you on how to set up my RBK53 (1 router unit and 2 satelitte system) that I bought from Costco.
