Walkmic3
Oct 17, 2017Guide
Orbi Losing wifi connection
I have had the Orbi AC 2200 for a month now. 2 to 3 times a week we completely lose our wifi.
EnolaGuy
Dec 30, 2017Aspirant
Well, I purchased one of these. I did not put my existing router into bridge mode, but I did turn off it's wireless and only have my ORBI router plugged into it. Everything seems to fine using my existing router as the gateway, so I guess I'll leave it that way.
sleepr88
Jan 02, 2018Apprentice
the problem is coming from Android Oreo devices... I verified by turning off wifi on my phone last night, haven't had any issues with Orbi... Netgear still has to come up with a fix for their end, because no way should a client be able to disrupt and REBOOT a router!
- wase4711Jan 02, 2018Luminary
no oreo devices in my house and the internet was dropping all the time, so that isnt the reason...plus, dozens of others have the dropping issue without any oreo OS on their devices..
- DarrenMJan 04, 2018Sr. NETGEAR Moderator
We currently have a beta firmware with many fixes for the 2.1.1 firmware you can find it here.
https://community.netgear.com/t5/Orbi/OrbiOS-2-1-1/m-p/1476960#M19962
DarrenM
- cyougerMar 07, 2018Aspirant
Good afternoon Darren,
I am using a RBR50 orbi and have ensured I am on the most recent Firmware and have made sure my wifi on the AT&T router is inactive but still have multiple internet disconnects a day. My devices will not even show being connected to the Orbi...
Is there anything you can do to assist?
Thanks
- FURRYe38Mar 07, 2018Guru - Experienced User
Is the ATT modem/router in bridge mode or still running in router modem? If it's still in router mode, use the DMZ on the modem for the IP address the Orbi router gets from the ISP modem.
Try the following on the Orbi router:
try temporarily disabling Fast Roaming, Daisy Chaining, beamforming and MIMO. Daisy chaining is only needed of you have two or more Satellites. Enable Beamforming and MIMO later on after checking the system out with out them being disabled.
https://community.netgear.com/t5/Orbi/Orbi-randomly-dropping-internet-connection-despite-V2-0-0-74/m-p/1481358#M20555Set manual channel 1, 6 or 11
Set WPA2 and AES only.
cyougerwrote:Good afternoon Darren,
Thanks
