flamenca
Mar 27, 2017Tutor
Orbi lost download speed
Help! I have newly acquired the Orbi RBR50 system. I have lost totally nearly all of my download speed from my modem. Have contacted my IP and there are no problems with the system. I have a sate...
TomMac
Mar 27, 2017Guru
Have you done a factory reset on the units?
Don't think it's your phone as they usu operate on the L band, 1616 - 1626.5 MHz
flamenca
Mar 28, 2017Tutor
Do you mean a reset? I have done that but still do not receive a full signal. If I just connect the router the signal is stronger (not as stong as it should be) but the moment that I connect te satellite Orbi the signal becomed weaker nor stops altogether. Would it help to connect the router to the satellite router with a ethernet cable?
- TomMacMar 29, 2017Guru
don't believe you can use ethernet cable for the backhaul channel .
