pelliot
May 18, 2022Tutor
Orbi lte lbr20 good signal from at&t but no internet
I had AT&T on the phone and they said everything looked good on there end. I'm using a prepaid SIM card, I get 5 bars on the indicator but there is no internet connection. I've rebooted the unit seve...
pelliot
May 18, 2022Tutor
did exactly as you directed. did not work. any other ideas?
pelliot
May 18, 2022Tutor
when I connect on my iPhone orbit app it connects to the orbi shows the carrier AT&T, signal lte, internet offline
- plemansMay 19, 2022Guru - Experienced User
Some carries won't let you use a phone sim in a hotspot/router. Did you contact the ISP to see if this is allowed?
They've gotten sneakier of late with it because of people using grandfathered-in unlimited plans on hotspots or routers.
- pelliotMay 19, 2022Tutor
Going to the att store today to check this out. Thanks
