WaltO
Sep 19, 2020Tutor
Orbi LTE LBR20 on AT&T
I bought this to replace my Nighthawk M1. My primary internet connection at home is AT&T LTE. I had to go to AT&T store and tell them I replacing my Nighthawk because it was dying and they swapped ou...
- Sep 20, 2020
Great news. Please marked as solved so others who are having similar issues can see the solution.
CactusHill
Sep 25, 2020Guide
What APN information did you use for AT&T to get it to work? I have not been able to get it to connect to the AT&T network successfully.
Thanks!
- WaltOSep 25, 2020TutorI tried them all using the Orbi App.
When I logged into router directly using web browser on my Mac it auto configured and used “broadband” as the APN. I did try “broadband” when I was using the App.
