packer_man
Mar 23, 2023Follower
Orbi LTE Router LBR20
I have a 1 year old Orbi LTE Router LBR20, using Verizon SIM Card.Orbi disconnects several times per week and rarely has a GOOD signal strength. I can place my I-Phone with hotspot on next to home PC...
KevinLiT
Mar 23, 2023NETGEAR Moderator
Hello packer_man,
Welcome to the NETGEAR Community!
I understand that you are having issues with your internet connection via mobile broadband. Your LBR20 is capable of the following wireless speeds using LTE ->2.4GHz (400Mbps†) + 5GHz (866Mbps†).
Incorrect configuration of the mobile broadband PDP, authentication method, and credentials can cause the network stability issues that you have been experiencing. First, ensure that "Always use 3G/4G mobile connection" is enabled.
Then ensure that you power cycle your LBR20. Once completed, please follow guidance from your ISP to configure the mobile broadband PDP, authentication method, and credentials. Please note that your ISP may require a PIN or PUK for mobile broadband for network connectivity.
Please go to the following settings to verify your mobile broadband network mode: ADVANCED > Setup > Internet Setup > Mobile Broadband Settings>Internet Connection Mode> "Always use 3G/4G mobile connection".
(Please note the settings above are settings that you will need to navigate to configure your ISP settings.)
Best,
Kevin
Community Team
