SRudy's avatar
SRudy
Orbi Lyric disconnects
For some reason I keep getting alerted that my Honeywell Lyric thermostat is disconnected from the internet. I have not had any other issues with Orbi. No other devices drop off. I am using the newest firmware and did a factory reset. I have no idea why this is happening. Any ideas?
  • FURRYe38's avatar
    What FW version is loaded on the router?
    How far away is the device from the router or satellie?
    Try disabling these options and see if anything better happens:
    Beamforming, MIMO, Daisy Chain and Fast Roaming?
    • SRudy's avatar
      SRudy
      I am currently on 2.1.3. I’ll play with the features but right now beamfoaming is on, fast roam is on and MIMO is off. Daisy chain is also off.
      The thermostat is about 15 feet from the router and maybe 20 to a satellite.
      • FURRYe38's avatar
        Beamforming should be ok enabled. I have mine enabled and my two NEST controllers are working. I do notice sometimes I get disconnections in the mobile app however I check the device and it's connected. Very random though.
