OB__
May 05, 2019Initiate
Orbi Main vs Guest Network Speed difference
Hi wondering if anyone has noticed the same issue I am having and knows of a solution.
I have guest network enabled and for some reason the guest network has faster download and upload speeds and ...
May 06, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
OB__
May 06, 2019Initiate
Just got the system
Updated both the Orbi Router and Satellite to the latest firmware.
Sagem f3284dc, as it has wifi built in and as there was some conflicts with some pages not being accessible even after setting the NG ip in the DNZ and passthrough and it still not working the router is now set in Bridge mode.
Orbi system is operating in Router mode.
After some more testing the speed seems to vary A LOT on both the regular SSID and the guest SSID.
E.g. last night it was 130Mbps, this morning had a hard time hitting 25, later around 80 all this without there being more devices connected and without any additional networks in the area that might crowd up airspace.
Let me know if you need any more details.
Thx
- FURRYe38May 06, 2019Guru - Experienced User
Ok as long as the ISP modem is in bridge mode you'll be fine there.
What are the wired LAN cable speeds with a PC?
What wireless devices are you using to speed test?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
