OB__
May 05, 2019Initiate
Orbi Main vs Guest Network Speed difference
Hi wondering if anyone has noticed the same issue I am having and knows of a solution.
I have guest network enabled and for some reason the guest network has faster download and upload speeds and ...
Mojo_Jojo
May 09, 2019Initiate
Just to add a little more. I have updated the router to the latest firmware as of this posting (2.3.1.60) and the problem still exists after the update. The performance difference is seen from the same machine at the same location in my house, I'm just switching from my main orbi wireless to the guest network.
May 09, 2019Guru - Experienced User
Has a factory reset and setup from scratch been performed yet since the update?
What are the wired LAN cable speeds with a PC?
What wireless devices are you using to speed test?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
