TomFrommack
Dec 16, 2017Initiate
ORBI manual channel selection
My Internet Provider is wireless in our rural area. The ISP radios operate in 2.4GHz. My current wifi mesh (Google) does not provide any ability to manually deconflict channel contention in this case...
debwillia
Mar 20, 2018Aspirant
From where???
I can’t click on a left hand if I don’t have a link!
webminster
Mar 20, 2018Luminary
You do know how to get to the Web UI, right? http://orbilogin.com/
- swiederAug 31, 2018Tutor
After a week of use with the Orbi system, I am replacing it with Three NetGear WAC510 wireless access points. I am not happy with all three Orbis being on the same WiFi channels. The WAC510's look alot more configurable. The price is about the same, about $300.
There may be a bit of extra setup. As a networking guy it should be fine.
Orbi seems okay for casual users, but I want more options.
- LauralbAug 31, 2018TutorAre they stand alone routers as well? Or do you have a different one as your main router?
- swiederSep 01, 2018Tutor
They are routers that I will run in AP mode. All with the same SSID and different Wi-Fi channels.
