jamination
Aug 20, 2019Aspirant
Orbi Max Speed Lan
Recenlty I upgraded my internet from 240 download (static ip) to 640 dynamic ip. I changed the router to dynamic ip and the LAN speed tests were coming in far short (about 180), however the orbi spe...
Aug 21, 2019Guru - Experienced User
FYI:
jamination
Aug 21, 2019Aspirant
The modem is an Arris Touchstone TG2472.
Phil
- FURRYe38Aug 21, 2019Guru - Experienced User
You have a gateway modem/router unit. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
jamination wrote:The modem is an Arris Touchstone TG2472.
Phil
