jamination
Aug 20, 2019Aspirant
Orbi Max Speed Lan
Recenlty I upgraded my internet from 240 download (static ip) to 640 dynamic ip. I changed the router to dynamic ip and the LAN speed tests were coming in far short (about 180), however the orbi spe...
jamination
Aug 21, 2019Aspirant
The modem is an Arris Touchstone TG2472.
Phil
Aug 21, 2019Guru - Experienced User
You have a gateway modem/router unit. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
jamination wrote:The modem is an Arris Touchstone TG2472.
Phil
