rdpjr57
Apr 25, 2021Aspirant
Orbi Mesh AX6000 account question
I have an existing Orbi system on an exisiting Netgear account. I want to put a new AX600 Orbi mesh at a new location. Can they both be on the same Netgear account or do they need to have seperate ac...
- Apr 25, 2021
I thank you. Had you done this the first time, directly, we both wouldn't have wasted time with extraneous texting and minimized the frustartion in searching out an answer to a problem.
Apr 26, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
