mkallen
Aug 27, 2019Aspirant
Orbi mesh extending existing network (same SSID)
We're looking to keep the same SSID for a Wifi network, but extend it via an Orbi mesh setup. Is this possible - where we would setup the base unit into a "bridge" mode and all the satellites become...
- Aug 27, 2019
Exactly. If Orbi will be the only WiFi and the Cisco will continue to assign IP addresses, all should be good provided you can connect satellites to the router. Any time someone mentions words like "concrete", "stone", "brick walls", etc. WiFi begins to have issues.
The ideal thing is to run ethernet cables to connect the satellites.
CrimpOn
Aug 27, 2019Guru - Experienced User
mkallen
Thank you! Yes, we had tried with Google Wifi this EXACT thing, all wired to router, and unfortunately the only option 'Bridge' mode doesn't allow when in a mesh setup. We will be going with Orbi now :)
