Sparxycat
Jul 31, 2023Follower
Orbi mesh network and Netflix UK on Samsung tv
Hi all, I'm having issues with netflix in the UK. My Samsung TV is connected via WiFi to my main router about 2m of open air between them. Netflix is majorly struggling to play and when going on...
michaelkenward
Aug 01, 2023Guru - Experienced User
Netflix is majorly struggling to play and when going on the fast.com webpage it struggles to get to 32mb whereas on speed test it gets up to my usual 72mb. It only appears to be netflix. All other streaming services (Disney, Amazon etc) all work perfectly fine with no issues.
32 Mbps is plenty fast enough for most streaming.
Close enough for an Ethernet cable if the TV supports it.
