GTGeek88
May 19, 2020Guide
Orbi mesh network question
It appears Netgear and Linksys and maybe others can't seem to explain the mesh network that well. And it seems Netgear has no pre-sales tech support, so here I am. I guess most people don't have wir...
- May 19, 2020
GTGeek88 wrote:So what I'm looking for is a system where each node of the wireless system plugs into the wired network and gives you a seamless and fast wireless network. Is this possible with the Orbi system or any other mesh system?
All models of Orbi which include ethernet ports can be connected over ethernet. (This leave out the least expensive, newest model RBR10 series, becauses the satellites have no ethernet port.
The KEY to this is that the satellites need to be connected to the Orbi router LAN ports. There have been some active discussions about pitfalls when "smart" or "green" ethernet switches are used between the router and satellite.
But, yes. This is exactly how people lucky enough to have ethernet wiring typically run their Orbi systems.
CrimpOn
May 19, 2020Guru - Experienced User
- GTGeek88May 19, 2020Guide
Thank you. That answers the basic question, but now I'm wondering what the issue with the switch is. I've got a Netgear GS116 switch. I'm wondering how to search for these discussions. Do you have any links to such discussions?
