lostwhirley
May 04, 2020Aspirant
ORBI MESH RBK23 drops WLAN a/n/ac consistently
I'm noticiing that my TXPkts drops down to zero consistantly. I'd say at least once every 30 seconds, the Transmitting packet shows that it drops to 0. Comes back up immediately, then drops to zero ~...
May 04, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
lostwhirley
Firmware : -- 2.3.5.30
-- Netgear Model c3000
-- Router
3 levels (including basement). Around 2800 Sq. Ft.
- FURRYe38May 04, 2020Guru - Experienced User
Your modem has a built in router and wifi already. Is the modem bridged? It can be and is recommended to be bridged if your going to use a Orbi system with it.
- lostwhirleyMay 04, 2020Aspirant
How do I find out if it's bridged?
Review the user manual for the C series modem. There will be a router mode or NAT mode feature somewhere in the modems UI. Use a web browser and navigate to 192.168.0.1.
