yuvismahi2
Jul 03, 2020Follower
ORBI Mesh RBK53S Router + 2 Satellites
I bought the Costco bundle of the ORBI RBK53S system that came with the router and 2 Satellites and I find that it doesn't give me full coverage of my home. I need to add more Satellites for covera...
Jul 03, 2020Guru - Experienced User
yuvismahi2 wrote:I bought the Costco bundle of the ORBI RBK53S system that came with the router and 2 Satellites and I find that it doesn't give me full coverage of my home. I need to add more Satellites for coverage but cannot seem to find them in stock anywhere. Any suggestions? I have a pretty large house with 4 floors and 6 bedrooms and need 1/2 more satellites. What would be the recommend and most cost efficient way to expand my orbi mesh network?
The few satellites that I could find were either for an older router or cost prohibitive where I could almost just by the Mesh 6 system for relatively the same price. If I did that, could i use that bundle with my 2 satellites from the RBK53S system?
