Christian17
Jun 27, 2021Guide
Orbi Mesh RBR 20 - Problem PS4
Hallo liebe Community! Ich habe den RBR mit einem Satelliten installiert. Ich habe das Problem, dass ich, aktuell bei einem PS4 Spiel Probleme mit der Netzwerk-Vebindung habe. Jedoch wenn ich am Sate...
Jul 01, 2021Guru - Experienced User
Englisch Bitte
- Christian17Jul 01, 2021GuideHi FURRYe38,
I have an issue with the WLAN of the Orbi.
The connection to the PlayStation is very well, but I don’t get access to the server of each game.
This issue came up several weeks ago.
If I connect the Orbi directly with the LAN then everything it’s working.
I restart the system several times.
The newest Firmware is installed.
The WLAN connection with the main router of the internet provider it’s working.
However, there is an issue with the WLAN of the Orbi.
I would be very happy about some helpful responses!!
Thanks!
Christian17- FURRYe38Jul 01, 2021Guru - Experienced User
So is the PS wired to the Orbi RBR when it works and if the PS is wireless, it doesn't work?
- Christian17Jul 01, 2021GuideThat’s right.
The wireless connection is working, but I don’t get access to the online function of each game.
