Christian17
Jun 27, 2021Guide
Orbi Mesh RBR 20 - Problem PS4
Hallo liebe Community! Ich habe den RBR mit einem Satelliten installiert. Ich habe das Problem, dass ich, aktuell bei einem PS4 Spiel Probleme mit der Netzwerk-Vebindung habe. Jedoch wenn ich am Sate...
Jul 01, 2021Guru - Experienced User
Englisch Bitte
Christian17
Jul 01, 2021Guide
Hi FURRYe38,
I have an issue with the WLAN of the Orbi.
The connection to the PlayStation is very well, but I don’t get access to the server of each game.
This issue came up several weeks ago.
If I connect the Orbi directly with the LAN then everything it’s working.
I restart the system several times.
The newest Firmware is installed.
The WLAN connection with the main router of the internet provider it’s working.
However, there is an issue with the WLAN of the Orbi.
I would be very happy about some helpful responses!!
Thanks!
Christian17
Thanks!
Christian17
- FURRYe38Jul 01, 2021Guru - Experienced User
So is the PS wired to the Orbi RBR when it works and if the PS is wireless, it doesn't work?
- Christian17Jul 01, 2021GuideThat’s right.
The wireless connection is working, but I don’t get access to the online function of each game.- FURRYe38Jul 01, 2021Guru - Experienced User
Possbile that this could be a PS issue rather than Orbi if the wired portion of the PS works and wireless doesn't.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless SettingsOne User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026If nothing here seems to help, I'd contact Sony for additional help and support regarding the wifi portion of the PS. There maybe a fault here.
