dferraro
May 24, 2022Follower
Orbi Mesh RBR10
How do I determine if my network is set to 5 GHZ or 2.4 GHZ and how do I change it if needed?
KevinLiT
May 24, 2022NETGEAR Moderator
Hello dferraro ,
I understand you that would like to know which network band you are using on your network and if there is a way to manually pick a network band. For the RBR10 there is no way to choose the desired network band. This is applied automatically depending on the most optimal network band for the device.
To figure out which network band you are using please follow the steps below.
On a Windows PC, simply do the following:
Select the Wi-Fi icon on the taskbar
Then select properties
Next, scroll down to "Network Band".
Finally, You will see either 5GHz or 2.4GHz
Let me know if you have any additional questions!!!
Best,
Kevin
Community Team
