MKC1298
Jul 08, 2020Aspirant
Orbi Mesh Router
I am looking to exchnage out my Optimum Router with an Orbi Mesh Router... Just not sure if it will work. Looking for any advice. Thank you
CrimpOn
Jul 08, 2020Guru - Experienced User
More information is required, such as the specific model of Optimum device.
Orbi WiFi routers do not include cable or fiber connections. They require a cable modem or a fiber ONT.
So, if the Optimum is a combination unit which includes the ISP media connection, you either have to purchase a replacement or keep the device and perhaps put it into "modem only" mode. (often called "bridge" or "passthrough" mode).
- MKC1298Jul 08, 2020Aspirant
Thank you for responding, I have an opitmum Saagemcom router and an Arris TM1602 modem. I am looking ofr better bandwidth in my home. Opitmum has been terrible and I was recommndd to going with an Oribi Mesh Router. I just wan to make sure I order the right item to give me what I need,
- FURRYe38Jul 08, 2020Guru - Experienced User
https://community.netgear.com/t5/Orbi/Find-Your-Orbi-With-the-NEW-Orbi-Product-Selector/m-p/1907267/highlight/true#M91216
https://www.netgear.com/orbi/default.aspx
https://www.netgear.com/orbi/wifi-systems.aspx
https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-Systems- MKC1298Jul 08, 2020Aspirant
Thank you but can not follow... But I appreciate your responding
- CrimpOnJul 08, 2020Guru - Experienced User
Thanks for the information. Any WiFi router will connect to the Arris modem. There are (literally) dozens of WiFi routers on the market, including:
- Mesh systems which promise to provide a wider coverage area than a single WiFi radio can.
- WiFi 6 systems which support more and faster connections to new WiFi 6 products that are beginning to appear.
- "Gaming" routers where the emphasis is on low latency for internet gaming.
- (and almost every combination possible)
FURRYe38has provided some links to good references about how to choose a WiFi system.
I would encourage you to compile some relevant information, such as:
- The size, shape, and construction of the building. Is it "long and narrow" or "relatively square"?
How many floors? Are the walls modern "studs and drywall" or concrete? - Do you want coverage to outside areas?
- Where is the internet modem located in the building?
A central location allows one router to cover more "inside", whereas a modem located in a far corner (like mine) means that a large portion of the WiFi radio is broadcast "outside" and probably in a direction that is not useful. - Where in the building are the principal WiFi devices?
- Do you have (or is it easy to install) ethernet cables from the modem location to other parts of the house?
Or, from the modem to a central place where cables can be run to the rest of the house. - Is the principal complaint today (a) lack of WiFi coverage in certain places, or (b) there is coverage but performance is too slow.
I purchased an Orbi system in 2016 to replace my Nighthawk R7000. I have been really happy with it. Part of this appears to be pure luck, because I have experienced none of the issues which I see reported on this forum. I plan to keep using the Orbi until there is a damn good reason to replace it with the "latest and greatest". But to be brutally honest, if I were purchasing a new WiFi mesh system today, I would have to get a really good deal on a 2016 model Orbi system to make it worth investing in.
Thank you so very much!!!!
